having a problem with it blowing fuse f101 after about 30 minutes?graphics get scrambled 5 min. before this happens. any ideas, or where i should look?(i replaced the two trans caps on the side of the chassi) no change.
Get your tempest game board fixed. When the board heats up, somethings going apeshit and overdriving your 6100. Try reseating all the socketed chips and the interconnect cable. Id guess though its in the vector output or power supply.
It takes a network of friends but I would try swapping the monitor and then the logic into a working cabinet. With this method at least you know where the issue is if the problem transfers into the test/ working game.
