60n1 and dell monitor help?
partygt
California
got a few dells that wont go full screen?
try factory reset,position,clock ect still off to the right?
any help would be great. thanks Paul
there are some compatibilities with certain VGA monitors. once you come up with one, you have to change the board to a different 60:1 factory board (there are clones of clones) or different monitor.
There is no "settings help" to solve your problems.
Of all the brands I have tried of LCD monitors, Dells are the only ones which have had compatibility issues. About 50% that I've used dont sync right with the icade board. No idea why.
Hook the monitor up to your computer and change the resolution on it to as low as it will go. I have had this problem a couple of times before when using an LCD monitor. Some of them dont need it but i do this as a standard practice before mounting anymore.
Put it into test mode with the cross hatch pattern and then try to auto adjust the screen. I normally have to press the auto adjust 3-4 times on dells to get them to fully adjust. I just installed 10 dells and had no issues with any of them.
-Jake
