60in1 cp's for pac cocktail
goleafs0
Hamilton, Ontario, Canada
I had a problem trying to find cp's for my pac cocktail with the 11" wide control panels. I wanted to make it a 60 in 1 with three buttons so I tweaked the original pac cp's. The good thing is that the first button lines up with the joystick hole so no need to fill in any holes just cut some new ones. You also have to use ms pac joysticks with the smaller mounting bolt pattern. Tell me what you think.
These look good. I would be interested in a two button version rather than three, esp if that allows me to keep the original joysticks. How much do you think would go for?
-PC
Thanks for the file goleafs0. I was able to take your file and mod it into a two button version that can use the original wide pac-man joystick. Having is made at mamemarques...
