60 n 1 wiring
HAVASUGAMEMAN
lake havasu city, Arizona
any one know the two wires that need to be connected to the coin switch? and the dip sw. setting for coin mode want to turn this machine into coin op to put out on location thanks
To make it coin op, you have to have a test button. The only way to make it coin op is to go into the test mode and change it there. The two wires going to the coin switch should be Coin 1 and Coin Counter, I believe. It also needs a ground. If you need further help please PM me so I can explain it better.
Shouldn't it be Coin 1 and GND for the coin switch.
And Coin Counter + GND to the coincounter...?
The way my PCB worked I had to do it that way...Not sure why. I was confused to. I tried it that way and it worked. If I didn't have the coin counter wired it wouldn't register the coin.
