60-n-1 LED question
Spyridon
Chester Springs, Pennsylvania
Does anyone know what LED's 1, 2, and 3 are for on the 60-1 board? On my board, LED 3 flashes red, LED 2 flashed yellow briefly, and LED 1 flahse yellow. In tune with the LED flashing, the monitor will blink on and off with a white screen.
My 60 in 1 only has 2 lights. One stays Green the whole time, the other flashes Yellow (orange) and then blinks green.
Not sure if that helps.
It's not good what ever it means. A red LED on a multi board means problems.
Red usually means a boot problem, either due to too much or too little voltage coming to the board. Your +5 should be between +5.00 and +5.20. I always set it at +5.10 so if it drops a little under load, it'll be okay.
Hopefully - if it's too high - you can turn it down and it'll work, and nothing got fried...
It's in a Pac-man cab with a lizard lick board. It's not mine so I will have to go over to the guys house to check the voltage. How do you adjust the voltage on a stock pac-man cab?
Well, you can't, but check the voltages anyway. It might be a bad fuse (missing voltage). And it wouldn't be the first time that a Pac transformer has failed.
Possible that the adapter's rectifying circuit could be bad, too...
