It depends on your budget and what you want for a finished product. Although the 60 in 1 gets much maligned around here, if you are new to the hobby it is a great place to start. If I had that machine I would replace the marquee with an original or repro ladybug marquee. Assuming the wiring is in poor shape, I would require for jamma and install a 60in1. If you decide you want to run an original board you can just use a jamma adapter on your original. If your wiring is in good shape go the other way.
