60 in 1 video issues (To much red)
pfunk0320
austin, Texas
HELP!
I installed my 60 in 1 and the games play fine. Only issue I have is, instead of a black background in each game its a red tint. I have tried making every adjustments, from Changing the contrast darker to brightness, to turning red completely off. I have attached (2) photos to give you a better idea of my issue. I have spend over 2 days trying to correct this and I am about to go mad.
I know its not the issue with the monitor or going defective, cause I just changed this from non-jamma to jamma. All the colors perfect with the old game.
Here is the same monitor where you can see at the top the black is fine with no red tint.
Yes, this is a monitor issue, either with the color adjustments or the wiring. Were you the one that left a message at my work about this?
I had a JAMMA cabinet that had a similar problem with a 60 in 1. I disconnected the -5V from the PS and the colors went normal.
It looks like a wiring problem though. Post a picture of your monitor connections.
Issue has been fixed. Wiring from harness to monitor connector wasn't matched up properly....
So true! Wiring was incorrect. In fact learned alot more about wiring and my games in general Thankful to S & B!
