60 in 1 cutting off part of the bottom of the screen
rabidewok
League City, Texas
My 60 in1 has an lcd installed and it is cutting off the bottom of the screen, like maybe a half inch. I have adjusted everything i can. Like on Galaga it cuts off most of my lives on the bottom of the screen. It cuts off the words free play etc.. on the home screen. Anyone have any advice
What size screen are you using? if its not a 19" or larger I have had problems with smaller LCD's in my 60-1 as well. Once I switched to a larger screen I did not have any of the problems as before.
Mine has a similar deal, not as bad though and I don't really even notice anymore.
That being said, could you route it through a cga > vga converter? That might allow you more fine control than the 60n1. I originally meant to do that when I saw the offet.
I had this problem and I was so pissed but then I fixed it by messing with the buttons on the LCD monitor. There's a button that fits the image right. Don't know what its called but when I pressed it it fixed everything.
Your LCD monitor should have buttons to adjust the screen size, some even have an auto adjust image-which when the correct button is pressed, the image automaticaly fits the screen. On another note, the only other problem i have run into was that the resolution was set too high and would not display an image, so i hooked it up to a home computer adjusted the resolution down and then hooked it back up to the 60-1 pcb.
