60 in 1 control panel wiring
LasVegasIRA
Donor 2014-2015
Henderson, Nevada
I have a Ms Pacman cabinet that I want to use with a 60 in 1 board. The thing is, I want to be able to easily convert the game back to original so I don't want to cut up the CP.
Does anyone know if the 1P and 2P buttons can be wired in parallel to also be the 1st and 2nd "Fire" buttons on a 60 in 1?
Thanks.
Google hotrodarcade.com pacman jamma adapter. It does exactly what you want. I have one and it works great. I believe the seller is a member here. (SC93cobra might be the user name?)
There are other options as well...but this one specifically worked great for me.
His ID is kngcbra
I used his adapter on my pacman to run arcadeSD and works like a charm.. have to check with him if there is any issue using the adapter on a Ms pac but I wouldnt think so.
Just plug and play.. dont have to change a thing on the machine.
