those two are exactly the same as far as i can tell.
Just make sure you use an adapter to convert the AC going into a Pac board to the DC needed for the 60-in-1. If you don't convert it, you'll blow up the 60...
If i use the 60 in 1 i will just put an ATX or switcher in there...wont be using any of the original pac stuff.
That's the power supply. You still need a harness to route signals to the monitor, speakers, and control panel. If you use a new harness, then you're fine. But if you use the existing harness, you'll need an adapter - and you'll need to remove the four fuses on the bottom so the AC power is removed from the Pac edge connector...
All the games in the 60-in-1 are very close to the originals if not perfect, it's only the sound that's really poor on some of the games, although it seems to me this isn't a problem with the pac games.
They're a little off on Ms Pac (I think the sound the eyes make going back to the pen is the one that's off) but Jr Pac sounds pretty close.
i think you meant to say - "The caps on my dedicated Ms Pac board are original, so they don't filter the voltage quite as good as when new, causing the sound to be slightly different than when new. I can tell this because when I listen to the way they should be on the 60-in-1, they sound different than my original board."
Or not....![]()
