60 in 1 board problem
bbvending
Missouri
I have a 60 in 1 board that will not do anything but go into test mode. I have changed the dipswitch and nothing. It does the same thing no matter what position.
Tim
I figured out something. If I unhook the test and service swithes it works fine. I am checking the wiring now. I don't think I am hooking anything up wrong. Can any one help.
Tim
I had trouble with one of those a few years back, I believe the dip switch was upside down.
So, the first switch was the last switch.
Tim
I just wired in my first 60 in 1 and by stating that you un-hooked the test and service switch and it works fine, tells me that the physical switch that these were connected to is either bad or the wires were crossed somehow. Depending on the type of switch could make the difference.
Mine is a SPDT but one position is a momentary toggle, I wired that side to the service and the other side to the test. The center was my ground.
