midcoastsurf
Hello,
I have a 60-in-1 board that I recently hooked up and it worked fine. I adjusted the horizontal and vertical widths on my monitor via the coil and the little metal slit type potentiometer.
Somehow the colors are not showing up correctly and the graphics are not sharp in the "menu" screen of the multi-game. Also, ONLY in the menu screen, I get weird vertical white lines where it should be black. See attached pictures.
I had to take the monitor w/ chassis out and set it on the edge of the cocktail table to make the adjustments as I could not see anything with the monitor in the game (gotta love cocktails!) Any ideas on where to even begin with this? It seems I can't dial in the right color "pink" for Pinky in Ms. Pac and I can not get a good brown color (for barrels and monkey in DK). Maybe i disrupted a cracked solder joint on the chassis board? To change the colors, I was adusting the RGB dials on the neck board.
Any ideas? The colors displayed fine before I adjusted/messed up the monitor. This is a 19" Nanao monitor.
I am new to vids, so please be specific in your answer
Thanks in advance!
Thanks in advance!
