60 in 1 and 19 in 1 bulk buy, CHEAP!
armi0024
Donor 2012
Minneapolis, Minnesota
I have an order shipping on Tuesday from overseas, if anyone wants a discount on Icades here is your chance
60 in 1 Icade for 80 + 5 for shipping 1 (+ 10 for shipping more than one) (yes if you want 100 of them, I will cover the extra shipping)
19 in 1 Icade 90 + 5 for shipping 1 (+ 10 for shipping more than one)
All orders must be in by Monday 9/19
These are the small boards everyone else has been selling. These are the Chinese boards, not the Taiwanese boards.
have a couple questions about the 19-1 board. can i install it in a defender and have all the buttons work? do they work ok with older crt's? 4600's go7's? can it be set it up to just play defender?
Paul, I havent tested these on the older monitors, they are not an item I normally carry, I happen to have 1 small board 19 in 1 in stock and will test it on a 4600.
I typically sell the Taiwanese boards because they do work reliably and well, however, people have bombarded the market with cheap Chinese boards so I thought I'd open up a group buy on these.
The boards I am ordering will be the same exact boards everyone else is selling for 15-30 dollars more.
I don't usually carry these because I prefer the quality of the Taiwanese boards over the Chinese boards. The reason I am doing this so cheap is because they are much much cheaper to purchase wholesale. When people started dropping the prices on 60 and 1's and converted their stock to these, many of those vendors doubled their profit margins by selling the cheaper Chinese product, instead, I decided to do a group buy and pass the savings on.
I will test the small board I have for the invisio button.
People have confused the whole A boards vs. B boards discussion.
A boards by definition are the originals from the Taiwan factory. These are Chinese boards. I have not noticed any issues with the 19 in 1 I have.
If people want A boards they are always available, however, they are bit more than these in cost.
I am interested in a 6 button horizontal as well, specifically to play Stargate and a matching jamma harness with pins on 25, 26 and 11.
Good grief guys.... The Chinese boards are Chinese boards, I do have A boards available for 150 each. The Taiwanese boards don't have any issues, I will warranty them for 1 year.
4600 monitors, works fine, I'm not modding my Centi to test it on a GO7 sorry
P1 and P2 buttons 5 and 6, these do not work on the one I have in hand, however, I will ask to check on this for the upcoming order
A harness with pins 25, 26, and 11... Well we have a new adapter coming out will introduce pins 25 and 26 to any harness.... 11 you are on your own.
As far as I know ,old CRT monitors will work in most 60-1 ,19-1.
I used Happ ,newer WG,WG 7000 ,4900 ,4600 ,GO7 and Matsushita in those cabinet before .
I had a few problems with GO7 ,it always curl a little in one corer ,even after cap kit ,after done the curl fixed ,some GO7 monitors still curl a little ,some GO7 hard to get it sync ,need to change or clean the adjustment pot .
This is my understanding for those confused.
Taiwanese boards = A Boards
Chinese boards = B Boards
For the 60-in-1 there is no noticeable difference between the A and B (Taiwanese/Chinese) boards. Perhaps the components are cheaper. Perhaps they will last a shorter time. Who knows. Game-play wise... they are the same.
For the 19-in-1 it has been reported that there is a MAJOR difference between the A and B (Taiwanese and Chinese) boards. The B boards evidently do NOT have traces going to a couple buttons. What that means is that certain games can not have the proper button setups for the game (Defender/Stargate for sure)...
I do not own a 19-in-1 but this is what I've read in multiple reports.
Yes. So it is misleading for a PCB to be sold claiming to be able to play Defender and Stargate, when it is impossible for the boards to do so. There are no connections for pins 25, 26 and 11 on the cheaper 19 in 1's. Who needs reverse and inviso anyways?:rolleyes:
My understanding is that it CAN play Defender and Stargate, but reverse and what not are associated with the stick now...etc.
Just gonna guess here but I'd assume the stick still does the up down and then is set up for left and right for direction on say defender vs having a button. Possibly because the other games probably use a 4 or 8 way stick anyway and why clutter the cp with extra buttons. If this is true though and you don't mind the extra buttons for defender that would not be used on most other games any way then can't you simply daisy chain off the switches that go to the left and right directions on the stick and wire them to buttons? I would think it would work and you could now play defender with buttons with this board. Just a thought.
Could do that... but every time you pressed those buttons during other games they would cause whatever the game is to go left and right... but that's not a huge deal.
Thanks for passing on the pricing Bryan!!! Come on guys! This is the SAME 60 in 1 (smaller board) that others are selling for $100+!!! Questions are not needed... 19 in 1 has been available forever... Never used one... Probably never will so I have not experience with these!
Wow this is quite a discussion.
Frizz is right, traditionally the A vs. B was Taiwan vs Chinese.
However people have used "A" to describe any board that worked with two trackballs, which has become misleading. We used to stock Chinese boards, but exclusively stock Taiwanese boards now. We didn't like what we saw with the Chinese boards, however, every other vendor converted to these boards so I thought we would simply offer a presale.
If you want A quality boards it's 110 or 150 for 60 or 19 respectively. I would HIGHLY suggest that if you are concerned about all these issues that you look at the "A" boards, the programmables, or the ArcadeSD. The Chinese boards I'm offering in presale are the exact same boards sold by other vendors on this list as well as almost every online vendor except one.
That being said, the 60 in 1's are better than the 19's. The 19 I have in hand does not have a connections for the 5th and 6th buttons but does work with reverse on the joystick. The jumpers to buttons would be a great idea to solve part of this.
I just opened up the fact that I have a large order coming in from over seas to give people the opportunity to get some boards for a good price.
I put a 19-1 in a empty Defender cabinet for a guy once ,it was easy to do ,just replace joystick from 2 to 4 ways ,add ps ,jamma harness ,that is all .
All buttons are all working ,you can also use buttons or joystick to go back and forward ,joystick make game a little too easy .
The customer do not care about the #6 button for Stargate ,I did not add #6 button ,it was wired under control panel ,tested and it worked .
I told him not all games can be played ,like Robotron ,if he likes to keep Defender panel set up ,so he turned Robotron off .
When the bonehead who won my auction (over 2 weeks ago) for my Mortal Kombat comes to get it, which is also when I am to be paid, I'll be in for a couple 60-1s.
Thanx for passing these along
Sorry not ignoring everyone, I just got swamped at the day job, I will email everyone who sent money tomorrow to confirm, and email everyone who's PM'd to confirm check on whether they paid. On Thursday, order goes in Friday.
again the paypal is [email protected]
