60-1 test mode update.
noice87
Glenn Heights, Texas
I wired up a test switch (Wired to Service 14 and ground). When I turn the machine on with the service switch pressed it goes through the roms and then to the screen change size screen. The manual says pressing the service switch button again takes you to dip switches. But when I press it ti goes to I/O mode and will not leave this screen. I can test my buttoms and joystick but I really need it to go where I can put it on free play.
Thanks Steven
I just finished a 60 in 1 cocktail and experienced the exact same thing. To access the other service functions (basically ALL of them), you need to start the board with jumper pin #4 in the test position (I can't remember if it's on or off). It seems that all the service switch does is test for audio, screen size/colors and switch continuity.
You wired up the wrong switch input. There are two for the 60in1's - SERVICE and TEST. If you wire up the SERVICE input, then you only get the grid (with music) and input test screens. If you wire up the TEST input, you get the same, but with all of the dip switch setting screens in between...
My jamma harness was missing the test lead, I only connected service, so that was my only solution....
Thanks I wasn't sure which to use service or test. Will wire up test and see what happens.
Thanks Steven
Make sure you push Player 1 Start to save after you make changes...
