60-1 issues.. supposed to deliver tomorrow morning!! help!
cueball
Coatesville, Pennsylvania
I am finishing up a multicade and bought 2 60-1s from Nick. Ive never had an issue before and both of these boards dont seem to display with the correct colors. i understand some tweaks may be needed, but the 'icade' at the top looks washed out.
however if i put another jamma board in it, it looks great. even my personal 'icade' pcb looks better - but not as good as it does on my machine.
i am going to try the new pcbs in my machine to see whats up. again, ive never really needed to make much of an adjustment to brightness/contrast- only with width and positions when swapping pcbs..
thoughts!???
what type of monitor?
Has the monitor been recapped, etc. (if it's not an lcd, I assume it's not since you are plugging other jamma games into the edge connector)
If you have another machine that keeps your current icade in it, you should test both of the new boards in there.
ive managed to get one dialed in.. it is a wg4600.. one pcb may just be bad so i need to test it further on my machine.. now i just need to get it degaussed. the drill doesnt seem to work.. i may just move it to a different location in the garage.
You're making games for delivery as Xmas presents, and you use a drill to degauss? :rolleyes:
