60-1 bug on coin up on midway cabinets
r5g_on_klov
Nevada
interesting bug ive noticed on midway cabs
with 60-1 install
you need to cut out the old caps from the coin sw input tabs area, and tilt area for the coin sw to work right on midway cabs, or other cabs with caps across coin sw.
failure to do so will result in alot of coin not registering, or coin tilt on screen
the timing the 60-1 program is looking for (for time length of closed sw)
is probably alot shorter than the midway games could take, and the caps probably elongated that compared to no caps there.
