squall280
I seen this mod done and was wondering how to do it.
I mean in the cab with normal crt's they are not next to each other. One is mounted normally and one is in the system and they use a mirror to display it next to the other. Kinda similar to the virtua cop machines where the monitor is in the base and the mirror was used to display the image(they did it in this to push the screen back further. At least that is how I remember it(I haven't taken one apart in a while).
You're right, one of the monitors is laying flat and a mirror is used to reflect it up next to the other monitor. I think it would be impossible to use actual boards and get this mod to work, because the image is reversed for the 2nd input. I'm sure Ground Kontrol just has a computer with MAME hooked up to the monitor.
The Ground Kontrol machine only has one screen. I assume they are running a MAME set-up.
It is one screen. I have played this glorious machine.
I bet it's a custom hardware hack by Clay.
curious about image quality. never seen an HD flat panel make lo-res video look good. but combining the screens into one seamless display is a nice trick. plus it appears they are saving a lot of space, since the cabinet has been... uh... sawed in half.
