Jimjaycee
I am working on getting one of these 6 player X-men cabinets put back together.
The inside mirror was removed by someone other than myself.
Now I'm trying to figure out how it gets installed. I have a piece of angle steel that appears to fit at the bottom end of the cabinets by the monitors.
If I'm right, the mirror is cradled in that steel, but I have no support/stop at the top.
There is a block of wood on both sides that still has a screw in it.
From looking at pictures posted online there appears to be a piece of plywood that sits inside the front glass & holds the mirror in place. If I'm correct, I need the dimensions so I can re-create the piece to fit in my project. I'm also curious if there's a piece of steel on that piece of plywood to keep the mirror in place. Any information & pictures would be helpful...
Jim
Jim
