6-in-1 jamma switcher: screen is flipped
stevenp61
Florida
[Figured this would fit better here than in the monitors subforum]
I have a cocktail cab with the jammaboards 6-in-1 switcher. I have 2 boards installed: the AS programmable and the iCade 60-in-1. 2 problems sprung up:
1) The iCade displays correctly, but the AS board is upside-down. (E.g., startup screen faces away from the Player 1 control side.) Is there any way to flip this without having to switch the yoke? (I *really* don't want to do this every time I switch boards!)
2) The monitor settings (position and width in both directions) is different for these 2 boards. Is there any way to get them both to display properly? They're a bit too far apart to find a "happy medium" setting for both boards.
So, is there a way to seamlessly switch between these 2 multiboards, or do I have to switch the yoke around AND re-do multiple settings on the monitor each time I switch boards? (Still hoping for option 'A'!!) Thx.
I don't have the AS manual handy, so I'm not sure if it has a screen flip option in the menu or the dip switches.
If not, then just flip the yoke connector, then flip dip switch #1 on the iCade to flip it's startup image back to the way it now....
I didn't see a screen flip option in the AS setup menus (might've missed it but I looked!). Flipping the yoke and the #1 dipswitch on the iCade did the trick though! Still have to adjust the monitor between the boards, though. The 'horizontal' adjustment (vertical position of the vertical screen) is off by more than a full inch between the boards. Thanks! If you're ever in NYC, beer's on me....
So, is there any way to avoid the screen shift and adjustments when switching boards?
