6 in 1 jamma pcb on ebay
DURANGOKING
kenosha, Wisconsin
Is it worth it .. neone bought one or currently using one. Would appreciate some input I'm liking the idea of 6 pcbs on 1 plug in play board
I have one and it works great.
Keep in mind that if you have pcb's that require -5v then you will have to mod the switcher to jump it to the slots that require the -5v.
There is also a problem using some fighting games like Mortal Combat,some have had to put diodes in for the controls to work properly.
Do a search here for the 6 in 1 switcher,there is plenty of info on them.
I've been doing a lot of research on them lately to build my X-Men 4P into a Konami 4P machine. I already have X-Men and TMNT, still looking for Simpsons, Sunset Riders and Captain America and the Avengers (not Konami, but harness works the same). I still need the Jamma 6-in-1 switcher to so I've been keeping an eye out for deals in regards to it.
The one on eBay will cost you $95 when all is said and done. Jammaboards.com sells theirs for $99.95 + shipping but you can have them install the -5v to whichever slots you need for an extra cost. That way, if you know a certain PCB needs the -5v you can have it ready to go when it shows up.
To my knowledge the boards I'm looking to play don't require that voltage, but I haven't found concrete evidence yet (can anybody confirm/deny that for me?).
Also, if you're using games with kick harness or Jamma+ support then you'll need to use diodes on the harnesses so the feedback doesn't effect your games. There is a good tut on this board if you search for it. Hope that helps.
