Aren't these 4k? Should do higher than 1080p, no?Bump! These are great webcams that can do 1080p at 60fps. A little better than entry-level, perfect for finally getting your stream together.
If you buy multiple, I'll cut you a deal.
Yes, that is correct, you can go up to 4K -- but not at 60fps.Aren't these 4k? Should do higher than 1080p, no?
I'm replacing them with Razer Kiyo Pro's. It's more of a size-grade than upgrade, as the specs are slightly less than the brio's, since they're a dedicated 1080p camera. But I really like the image quality of the Kiyo, and the FOV can go higher.I am curious though.. what does the OP plan to replace these with?
That's what I run my Lumix G95 DSLR camera at and it looks gorgeous. 4K is still 4K so I recommend using the higher resolution and not to worry about frame rates. 30 is plenty for gaming capture.Yes, that is correct, you can go up to 4K -- but not at 60fps.
I believe 4k runs at 30fps capture.
