4P Konami Owners - Help!
Ghostnuke
Lawrence, Kansas
I'm just about done with my TMNT restoration. I was assembling my control panel this afternoon and ran into a snag. All of the buttons I got use leaf switches like this one:
The problem I ran into is that the buttons are too short to reach the leaf switch. Did I get the wrong buttons? What buttons are standard in 4P Konamis? Micros? Any help would be appreciated.
I'm not sure if they came standard with leaf switches, but mine just has standard HAPP buttons with microswitches. Easy and cheap solution.
they look like the wrong kind. those ones have too much of a space between the contact points. the ones you need should be flatter.
Yeah, I really don't see how they would work. The button is too short to even screw into the mechanism, let alone move the switch.
Bey ghost come on out I should have some leaf buttons that will reach thrue your cp
I know I have some purple leafs i I thought You needed micros
Bring the whole cp worse case I bust out my router and we route the underside like on defender cabs
You could also route the button holes out some from below to make things fit. From above no one would ever know the differance. TMNT did come with leaf switches and leaf joysticks by default.
