49way joystick help
devils1982
New Jersey
picked up an NBA on NBC machine that was listed as "nonworking" for $105, replaced the cord and all is good.......except the player 3 joystick will not move to the right...it actually goes left when you push it right. So overall if you press up, it gos up, down, it goes down, left it goes left, and right IT ALSO GOES LEFT??
where do i start?
Are the connectors/wires the same for player 3 and 4?
If so, swap them and see if you have the same problem with the other joystick. If you don't then the problem is that particular joystick and I'd just replace it. 49 ways are pretty cheap if you get them used. I think I have 6 of them sitting in a box.
If you want to try and troubleshoot the problem on that particular joystick then perhaps someone else here can help you out.
thanks, i'll swap them tomorrow and see what i come up with. then i may be in the market for a couple 49s
