joeycuda
I'm hoping someone can help me figure this out - Paperboy project. Monitor was working, but cracked solder joints on input connector pins.
As I would in a restoration, I pulled the chassis, cleaned it, and replaced all the electrolytic caps, except the huge filter cap. Reflowed the input connector pins. Now, I get nothing on the screen (black).
Neck has glow, screen control has no effect.
I pulled it back out, verified that none are backwards, no leads left on and shorting, no solder splashes, caps have correct value (some higher voltage) - based on manual.
What should I check next? Thanks in advance!
Joey
Joey
