4900 to 4600 swap
if your 4900 chassis is dead wht not just fix the chassis.
then you would not have to swap the tube just yet.
and it would give you time to find a doner.
Peace
Buffett
Neck board solder pads are falling out and I've patched it up as much as i think i can. Otherwise, the rest of the 4900 is ok.
You can replace pads and traces with some stiff wire (or stranded wire coated with solder) - or just use coated wires to go from point A to B.
That being said, the tubes will work, but you have to swap the yoke as well.
