4900 Cap Kit Gone Bad
YellowDog
In Memoriam
Donor 2011, 2013
Humble, Texas
Did a cap kit on a 4900 a couple of days ago. Picture (minus screen burn) was perfect. Today I fired it up and the red was starting to bleed. Tuned up the red ajust and the red cutoff and it was fine. I decided to leave it on for a while to see and I just checked it. The colors have gone almost white and I turned the intensity all the way down to no avail.
Could I have gotten some bad caps, they were some brand I had never heard of. If so any hints on which ones to replace or is this monitor toast?
This is what it looks like now. That is a MS Pacman freeplay attract mode playing, in case you didn't recognize it.
ken
What happens when you turn the brightness on the fly down?
You adjusted the "black level" and the "screen" controls?
The brightness (screen) is all the way down & the black level was adjusted to the middle of the range.
B+ was measured at +133V.
This started a couple of hours after the cap kit, so that why I was suspecting a bad cap or one that went bad.
ken
On the input board is a transistor and zener diode for "blanking"... if the transistor and zener short you'll get a white screen like that.
RJ
Thanks RJ. I'll look at that when I pull it. If I can get replacements, I'll just replace them.
I have the previous 4900 chassis from this monitor. If I have the caps, I'll recap the old one and see if that works better. I have a couple of 4600 cap kits that I can steal caps from.
Update: I just checked the cross reference and there aren't many that I can steal. Oh well, I guess a trip to Fry's tomorrow :(
ken
First, if you have a rejuvenator, check the tube. You might have had an internal short lock the screen voltage high....
