Okay, I'm about ready to tackle my Sanyo monitor issue. But, before I finally do it, what's a snap cap? Something special I should know when getting this filter cap? Is there a type of 470uf 160v I should NOT get?
A snap cap simply has a couple of blade like terminals at the top of the cap for you to run leads to (or snap into place if there is a socket for it). Typically you find them to replace some of the older and larger axial caps (at least that's what I run into). A filter cap on a monitor board... you'll have to put the leads at the top and run a wire to the holes in the board to get it to work..but it should work no problem
