4606 wire connection help
toolguy
Michigan
I capped my WG 4606 and now have no pic. I have nice neck glow and nothing popped when I turned it on. It did work before capping it too. While trying to adjust the black pot, I saw this.
I noticed a 4 male pin connector on the daughter board labeled 1,2,3,4, above the black pot and a 4 pin male on the maroon larger board also labeled 1,2,3,4, near R622.
I have the white, blue, green and red, wire lead coming off the neck board, going to the larger board 4 male pin, but now am wondering if I connected it to the wrong board all along?
The long leads would imply to me that it goes to the 4 pin on the larger maroon board.
Could someone please verify which board this conenctor goes to?
Thanks,
No way! I had it in the larger board the entire time and this could be my issue!
I did see the witness marks on the male pins on the daughter board, so I started to doubt myself after seeing that.
Glad nothing blew up of course.
I just turned 40 in June, guess the old memory is not as good as it used to be!
Thanks, I'll try this tonight and see what happens.
