46-in-1 multi advice pleaee
Mango7
Rockville MD, Maryland
Hi guys. I have a 46 game in 1 multicade, which I'm told was a pac man in its previous life. My question is, can u tell me if its easy to.upgrade to a much higher, say, 150-in-1 card or board? I'm looking for good quality and mostly classic games. Thanks if u can suggest anything for me.
Kurt
Sorry if this is a stupidly simple inquiry
1) It's a 48-in-1, not a 46-in-1.
2) It is JAMMA, so you can swap in other JAMMA boards like the 60-in-1, Blue Elf II, etc.
3) Whether you can play all the games on the new board will depend on your control panel setup.
4) You may also need to change some power wiring if your current harness doesn't have the -5vdc connected or populated (not needed on the 48-in-1) and your new board requires it.
5) Also, moving to something like the Blue Elf II (horizontal games) will also require you to change the orientation of the monitor (48-in-1 has vertical games), which in a Pac cab will also require you to change the bezel...
Wow, thanks Mod! I'm going to get a separate machine for the horizontal games.
Can u recommend the best vertical board?. thanks again,
Kurt
