45cal gun games?
Choosterbuck
Toronto Ontario, ontario, Canada
Hey does anyone have a list of games that normaly use other guns that can be converted to 45cal guns. I have been recently informed that carnevil and ranger mission can be converted over to the 45cal guns as well as point blank1 and 2. Any other games have this feature? Is there a list anywhere?
For the atomiswave ranger mission and sports shooting are the only two that support those guns. You define ranger missions gun types in the setup. The other atomiswave gun games(clay shooting, extreme hunter 1 and 2) require the shotguns. Sports shooting came stock with its own guns with red dot sights on them. Hope that helps some.
I want to say Atari cops didn't use the standard happs 45 gun stock but it will work with an adapter. Forgot to mention it earlier.
Area 51 and Maximum Force from Atari use the 45 cal style guns. I don't know if other guns can work.
ken
ken
I meant guns that normaly use shotguns/namco guns that can be modified to use the 45cal guns instead. I'm looking into building a multi shooter cabinet, and I want to know what my options are.
So far I'm putting.
Area 51
Area 51 site 4
Carnevil
Ranger Mission
Point Blank
So far I'm putting.
Area 51
Area 51 site 4
Carnevil
Ranger Mission
Point Blank
Star Trek Voyager uses the Happ type guns. The dedicated came with the space guns but my NOS kit came with Happ 45 cal guns. I believe Police Trainer 2 uses the same hardware so the same guns too. Not sure about Crossfire Maximum paintball but it's a good bet it's the same guns also, all Teamplay games.
One thing to consider, Star Trek Voyager dedicated games only use a med res monitor but the kit board will use standard res or med res monitors. Not sure about Police Trainer 2 and Crossfire. You might want to check the other games on the list to see what type monitor they use.
lethal enforcers and invasion
i have a 6 in 1 jamma board that i, someday, want to make into a multi shooter in my carnevil showcase cabinet...
i'm thinking, but not sure, that we'll have to daisy chain the gun connectors on the pcb's together...any help/advice would be appreciated :)
I think the pump action is one of the things that makes CarnEvil so much fun. You can keep reloading without re-aiming. Can you not use the Midway sawed off shotguns with other games?
I think daisy chain is the only way unfortanatly :(
I have no idea, i was hoping they would work with other games i really like the pump action to. Does anyboady know. Even to use the sawed offs on buck hunter or extreme hunting would be pretty cool would be pretty
