Where these 75.00 last time? I was thinking about getting 3 when this run was coming up but i can'nt afford that now . :O(
Can you splice in 2 extra edge connectors, so I can hook up DK DKJR and DK3 with a switcher?![]()
when I needed to test a vs pcb in my popeye ct I compared the nintendo classic and vs pinouts, there is really nothing special about vs.
if you add a 2nd button for each player on the edge connector (there are pins for it) and cp harness, you could then make a very simple vs pcb adapter to use with your harness, if you can find the three pin berg connectors you could also make the vs gun harness.
that would be the ultimate nintendo harness.
Did some testing today. The new harness will support a total of 5 games depending on control panel option.
It's looking like choice 1 or 2
1 - works with DK 2 board, DK Junior, DK 3, and Popeye
2 - works with Mario Bros
More details to come. - Barry
Would it be possible to make an option for switchers?
Basically just chop off the power connector and label all the voltage lines?
I want to run swtichers in both my machines.
Still in for 1 dk and 1 popeye.
