3KOAM Angle Cabinet (Z-Back) Restoration
Couldn't believe it, but I actually still had the measurements saved in the notes on my phone! Bear in mind I went all the way around. Stock molding ends halfway on the bottom as well as near the rear access door on top, so I ordered more than the original amount.
My notes:
"T-molding 13/16" width, 186"/side (31' total for both sides)"
This will give you a little bit of extra just to be safe. Also, if you're NOT doing laminate (just paint or vinyl) you should use 3/4". 3/4" just wont be enough to cover laminate, hence the 13/16" in my notes.
How much t-molding did it take to cover the z-back?
