Yes, I'll do a quick mockup.Ah. I actually meant if you could share a napkin drawing with required measurements, I can easily 3D design something for ya.![]()
Scott C.
Yep, the marquee is just held between two vertical pieces of plastic. I printed it rotated on its side 90 degrees for better strength (printed as modeled would have layers stacked vertically, which are more prone to breaking if someone bumped/pushed on the marquee). STL file is attached... feel free to use it if it's helpful.What's holding the back of the marquee? The same as the front?
Scott C.
These may actually work, but they will need to be angled forward to offset the slop of the Williams mini cabinet top. If more support is needed, they could also be made wider, so more marquee is held.Yep, the marquee is just held between two vertical pieces of plastic. I printed it rotated on its side 90 degrees for better strength (printed as modeled would have layers stacked vertically, which are more prone to breaking if someone bumped/pushed on the marquee). STL file is attached... feel free to use it if it's helpful.
DogP
Well done!I'm still looking for a lower access panel for my Red Tent, so if you have an extra, let me know! In the meantime, I 3D-printed one from ABS to prevent anyone's electrifying encounter with the power chassis.
https://www.thingiverse.com/thing:6927268
You could 3D print a mold and cast one out of high strength epoxy? That would certainly last.I did a throttle cover for my After Burner Deluxe. No one has repro'd these yet, and they're all broken. We'll see how long my 3D-printed version lasts!
Printed in ASA, then painted with Krylon Fusion satin nickel, then Fusion clear gloss. The color match is good, but not perfect. Likewise, the print is a good replica, but not perfect. The original was vacuum formed, and it's tough to model the way the plastic flows.
https://www.thingiverse.com/thing:7007990
@Arcadenut printed this for me; he does amazing work, and super fast!Was doing some research on the pc10 holster and came across this 3D print model, and thus lead me to this thread lolis there someone on here that can print one of these bad boys for me?
https://www.thingiverse.com/thing:3538225
@braedel mau have plate and parts for sale.@Arcadenut printed this for me; he does amazing work, and super fast!
I'm wondering what hardware anyone has used for this to attach the holster part to the back plate? I believe the original had threaded parts on the backplate to grab a bolt, but obviously the printed one does not. Technically I could just use long screws to go all the way through to the wood, but i'd rather not. Bolts are out because they would create a gap on the back of the plate.
I actually was lucky enough to still have the metal back plate with threaded holes on my pc10-just no gun or holster. All I had to find was the proper Allen screws/washers to secure it@Arcadenut printed this for me; he does amazing work, and super fast!
I believe the back plate is mounted to the cab with carriage bolts (I'll confirm once I get home) and the 6 small holes on the back plate for the holster are threaded. Holster itself are just through holes on mine.How is it mounted? I can always add threaded inserts into what ever I print.
mine was also made by you!How is it mounted? I can always add threaded inserts into what ever I print.
You can always add threaded inserts to the backplate.@Arcadenut printed this for me; he does amazing work, and super fast!
can you link me a source?You can always add threaded inserts to the backplate.
As an example (from a completely non arcade related project)
Cool. Do you press-fit those, or epoxy?You can always add threaded inserts to the backplate.
