masterkas Well-known member Donor 2025 Joined Dec 20, 2010 Messages 1,163 Reaction score 66 Location California Apr 29, 2011 #1 Hi, I can't get the board to go into test mode. A test switch is not wired, when I turn dip #4 on the pcb and power up it still goes into game mode. The service switch is wired but all I get is two service screens. Any suggestions? Thanks
snapJaw New member Joined Oct 14, 2010 Messages 182 Reaction score 0 Location Michigan Apr 29, 2011 #2 Did you try using dip 3 or dip 2? If I recall, some of the 'old' boards might have used dip 3 instead of 4 for test mode.
OP OP masterkas Well-known member Donor 2025 Joined Dec 20, 2010 Messages 1,163 Reaction score 66 Location California Apr 29, 2011 #3 Figured it out So I found the ground and put a new switch in connected to service wire. Test mode now works!
kane086 New member Joined Apr 22, 2010 Messages 88 Reaction score 1 Location Melbourne, Vic, Australia Apr 29, 2011 #4 Yeah, that caught me out too, the 39-in-1s are different to the later 48 and 60s, you need an actual button wired up, you can't use dipswitch #4.
