#3 Display out on my FIRE! Need help
Zack5959
Indiana
After shopping the game out, no #3 display.
I will tell you now that when I lowered the backbox (one of many times) the entire display panel fell out and hit the cabinet...from a distance of about 4-5 inches.
All connectors are hooked, but its completely dead.
I removed the display entirely and found #3 seperated from its mounting pads, and it appears the display itself got shifted over based on the bent leads to the actual board.
I also studied the solder joints and they all appear perfect.
So my question is, can I simply verify the actual display is bad by putting it in test mode and verifying 100v at the pins?
Thanks in advance!
If 110v but data doesn't arrive then usually you see a small spot at the bottom glow a bit.
It's possible the glass itself broke and the gas inside left, then it's completely dead and you won't see anything glow.
