Does anyone have a schematic for a 27k7502 I found an open resistor at r310 and cant make out the colors on it for a replacement. I found the the schematic for k7500 but I am not sure if r310 is the same.
Joe
The schematic for the 25" and 27" are basically the same. there is a parts list in the 7500's service manual, with a listing at the end of the parts that were changed for the 27" version...
If R310 is open, then D310
could be shorted or a short on the video B+ line
to the neck board. The Video B+ should be high in ohms.
If low then theres a short on the neck board.
It go's to the collectors of the video amp transistors.
If you haven't replaced C310 you should or a cap kit.
