FS Parts: 27" Wells Gardner d9200 Monitor
Arcade22
Donor 3 years: 2012-2014
Georgia
27 " Wells-Gardner Digital Monitor, Model D9200 (WGM2792-UOTS30A, P857 Chasis)
Fully tested, fully functioning with a perfect picture and no screen burn. Barely used, been stored on a shelf for years.
$300 cash & carry in Atlanta, GA, No Shipping.
A full specs. sheet can be seen here:
http://www.wellsgardner.com/pdf/Spec/D9200_27_33.pdf
Power Input:
Input voltage: 90-264 VAC, 50-60Hz. No isolation transformer required.
Resolution / Graphics Modes:
CGA: 640 X 200
EGA: 640 X 400
VGA: 640 X 480
Input connector:
CGA/EGA: 0.156 center header, VGA: 15 pin D-sub high density male
Video input impedance.:
CGA/EGA: 4.7K Ohm, VGA: 75 Ohm
Video level:
CGA/EGA: 2.2 Vp-p, VGA: 0.7 Vp-p
Video type:
RGB analog
Sync type:
TTL sync; separate or composite, negative or positive
Sync input impedance:
2.2K Ohm (H sync and V sync)
Horizontal sync frequency:
15.75 to 31.5 KHz
Vertical sync frequency:
45 to 90 Hz
Just a late to the game update that this was SOLD a while back.
