27" old Sanyo TV - Possible Chassis Swap?
Wundercade
California
My 27" Sanyo CRT TV just stopped working, no power. I was wondering, is there an arcade monitor chassis that would be compatible with it?
It says the TV Chassis No. is 27580-00
And the TV Model No. is DS27580
Is there a chart or guide I can reference to see if there is compatibility?
Is your goal to create a 27" arcade monitor or restore your TV? If the goal is the arcade monitor you need to identify what neck board adaptor is used by the arcade chassis you want to swap in and then check the tube number against this list. Of course, you have the monitor so checking for the adaptor type first will be easier, then you can look for a chassis.
http://www.bkprecision.com/support/downloads/pdfs/CRT_Setup_Chart.pdf
