27" K7500 Medium Res Power Cord?
AgentAlbatross
Donor 2016, 2019
Wisconsin
See photo.
Where could I get one of these? Hope this is the right forum (as opposed to the trading parts forum).
Not even sure what brand of connector that is in the event I had to make one. Molex?
Cheers.
Wow thankyou. You and your online store rock!
I guess this is the correct Male connector part I need if I'm going to make up a cable?
https://www.arcadepartsandrepair.co...ins/amp-3-pin-mate-n-lok-male-plug-connector/
Looks like I also need to buy the pins too?
And a crimping tool. But holy ****.... looks these tools are like $400 - $600 online. That's nuts. Can you suggest alternatives?
Edit. I see you also sell this:
https://www.arcadepartsandrepair.co...ratcheting-open-barrel-contact-crimping-tool/
Would this be the right tool?
yes that tool will work well and i prefer this one.
https://www.arcadepartsandrepair.co...ckets-pins/open-barrel-contact-crimping-tool/
yes that is the correct mating connector.
here are the pins.
https://www.arcadepartsandrepair.co...-male-crimp-pins-18-24-awg-cut-strip-10-pack/
if you need female pins here they are
https://www.arcadepartsandrepair.co...ns-female-socket-18-24-awg-cut-strip-10-pack/
there are 100 packs of pins also if you need which are cheaper.
BTW: all our connectors have a two letter and four digit part number. for example CE1006 and everything with the same letter prefix go together to it easy for the customer. (so all CExxxx connectors and pins go together). i hope that makes sense. we had to make it easier since we have almost 300 connectors/pins so people can keep it straight.
Great, thankyou! Adding these to my list of things to order from your site.
here are the pins.
