25K7191 how to fix top of screen
blarue11
Aubrey, Texas
I am new to this =o) I recently got this machine a couple weeks ago. When I got it the top of the screen was distorted and the color was all off. I was able to adjust the coloring with the contrast and other knobs but im not sure how to fix the distortion/wave at the top. I do plan on getting a cap kit for it soon but was just wondering if that will fix it or if there is something else that needs to be done. Thanks for the assistance
there is a 50/60Hz pot located behind the Horizontal Hold pot. You can adjust it to see if this clears up.
Otherwise, you probably need a cap kit installed...
I had the exact problem recently on my K7000 and it turned out to be the tube. It was incompatible with the chassis. I put the chassis on another tube, and it cleared right up. I had already done a cap kit, so I know that wasn't it. Here are some pics...
This is the K7000 on the incompatible tube..
Here is the exact same chassis on a different tube with no adjustments or changes made...
It's possible that a cap kit will fix your problem, but I'd try adjusting the horizontal hold pot or the 50-60 pot.
