25K7101 Chassis Wiring Advice Needed
fleetwood472
Wisconsin
I just picked up a TMNT cab that was converted to Golden Tee and i'm now converting it back. I was removing the Golden Tee wiring harness today and noticed the black wire from the harness is in a different spot on the plug than the TMNT harness that I have. Before I install my TMNT harness I was wondering if this makes a difference with the black wire being in a different spot than the golden tee harness that was plugged in. Before removing the golden Tee insides the game worked fine and the monitor looked great. I just want to make sure that nothing will get messed up during the swap. I have attached 2 pictures. One shows the golden tee harness plugged into the chassis and the other shows the original TMNT harness. What do you guys think? Thanks - Justin
