Peale
cbuschief said:did you get the black hole fixed on your chassis? If not, test Q8....if it is working then your problem is in IC1
Good luck.
Q8 tests good, but replaced anyway with a known good one. No change.
IC1 replaced with one from a donor chassis. No change.
However; I do note a difference in reading from one chassis to another, when reading Q8 in circuit. Methinks something is off down the line. Now, I just need to track it down.
