25k7000 series vertical collapse
discgolfer72
overland park, Kansas
just got a few chassis in for a member her
im on the first one
pluged it in and just get a white line acroos the screen (left to fight )
pulled it out and recaped the chassis and still have a white line
where should i go from here (got my lil sis wedding in a hour or so argggg)
i did try 2 divvrent remote boards and same results
what section of the chassis controlls the vertical on these k7000
replaced ic3 still single line across the screen
now what lol
i also just went back and reflowed every single solder jount (just to be shure it was not a cold joint somewhere)
Measure the vertical yoke to make sure you are getting a reading. Check around the yoke connector fro cold solder or broken traces. I had one where the PCB was cracked right across one of the traces to the vertical yoke pin.
Also, check R91. Make sure you have +24vdc at pin 6 of IC3. Make sure C50 is in properly and there are no broken traces around any of those parts....
Thanks again out with the gf for tonnight I'll tear onto this beast again first thing in the am hopefully I can vet it going I'm tired of having 2 tubes sitting in the shop with no working chassis
does ic 3 require a mica inslator neither of my parts chassis had one installed
im going to order a new ic from bob (if he has them) when he gets more flybacks in
i checked the pcb under a mag and i dont see any scratched or cracked traceses
r91 meters fine out of circut
and c50 was replaced and installed the same as the old one (and it matches up with what is screened on the pcb)
arggggg man stupid k7000's 3 25 inch chassis sittibg in front of me and a 19 and i cant get any working right
makes me wish i just had ez20 's siting around at least they are easy to fix from dead lol
ps i dont have a manual on hand right now
anyone know the pot values on the p802 remote boards
i have 2 that are mangled and i have a spare p718 that im hoping i can scavange ppots off of
reat assured once you suffer for the rest of us i will be adding this thread to the common k7000 sticky. Id also be thinking ics or something near the vertical yoke connection
dumb question and im sure it doesrnt apply but check r101 and its traces just for giggles
actually remove it and desolder because sometrimes the trace burns/gets oxidized black UNDER the solder.
also swap out c51 just for giggles
