K7000 25" with left side banding
Hey folks! I have a K7000 in my 3 player Rampart (also used to be a NeoGeo, and originally a PitFighter). Minor burn in on it. Monitor has been Bob Boberts kit capped, replaced Flyback, pots on remote board replaced. HOT is original. I'm seeing some banding on bright screens on the left...forums.arcade-museum.com
TLDR: Replace C204 with a 22uf 160v cap. If it's original, it's likely a ceramic cap. I've gone as high as 47uf for very faint stuff.
those are B+ filter failure symptoms (jailbars and the bright on left dark on right). wild that you're getting the same thing with multiple caps. now that I've gone public with how I work on these maybe you should find the R101 section part and try that out. lol
does turning flyback screen up/down change it at all?
Flyback, original or replacement?
