Ohmerone
Well I'll just add mine to the bunch!!! I have the horizontal raster lines also as pictured below. My chassis is a WG25K7191. I have neck glow obviously and my boards all work fine. At this point from what I have read here there is no solution to the problem so off to Arcade Cup it goes, I guess? I'm so damn tired of getting chassis fixed. I have another 25" wells setup that I will throw this chassis in tomorrow to see what it does. Can someone look at my other pic below to see if the connectors are in the correct orientation,they were hanging loose when I got the machine. Thanks!!!
Did you do a cap kit or replace any caps?
What parts have you replaced?
Your picture is to bright turn down the Screen Pot.
Let us know if it won't turn down..ccw
Check the wires from the main board to the remote board
they get dry-rotted and may break off at the back of chassis.
