25 inch monitor in 19inch place?
It looks like you have room. Would be easier if we could tell what kind of cabinet it is. Maybe get a pic of it from further back?
I once saw a 25" monitor mounted inside a Joust cab, so I know it will work if you have the room. You'll have to modify the mounting method, and obviously replace the bezel....
EDIT - BTW - don't forget it will stick out farther in the back, so you might not get the back door on without damaging the neck...
looks like a standard dynamo cab so yes the 25 should fit nicely
wow you hit it. it is a dynamo cabinet. and on the page for MKII the first pic is one of these with what looks like a 25" monitor.
anyone know much about these dyanmo cabs? looks like they just mass produced them for arcades.
Looks like the 25" is 2 inches wider than the 19"
hmmmm
i just measured mine and it's 25.5 inches wide. looking from the back it seems as if there's room on the sides (granted i may have to cut the plywood)
oh and a side note
are these the cabs that were on NickArcade?
here's a pic from the front, with the bezel off, and the MDF that surrounds it.
sorry for the giant pics last time boys, i haven't posted in so long on a forum, i forgot my edicate.
I think i can squeeze a 25 in there.
Huh -- I appear to have a Dynamo that is 25.5" wide too.
Sounds like it's the same one?
Mine has a 25" monitor mounted in it vertically.
Is yours cut corner?
