Smitty420
The candidates for the project at these two yokes. I have previously wrapped them similarly and then. Rewraping one with a formula developed for the 19" yoked derived from backwinding a donor Amplifone yoke. The one on the right was an older wind and the one on the left is new formula with more turns and extra turn on the cross back.
I will start by comparing the one two the other and then rewind the one on right to try and get matching results. Notice how one yoke has lager ferrites than the other yet the one.
To start the 6100 Horizontal ohm reading is 1.3 ohms. The Verticle wind I am trying to match is 0.6 ohms.
The one I am working with today is 1.0 on the Horizontal and my first wind on the Verticle is 0.6. Problem is not enough winds and geometry is off.
Wire size on 6100 yoke 0.46mm or 0.018" looking for proper wire size I believe I m looking for 24MAG WIRE. I have some previously used wire, I hope I have enough for a set. This will be my first real attempt to match this yoke as it's own process rather than using formula for other projects.
With the settings the same on the PAT9000 the geometry is way different, the Horizontal is close but the Vertical wind is off. This must be corrected by adding turns to match the 6100 yoke. The actual box is very close to be usable wind but we're going for consistency and repeatable results here, so I will re wind this yoke to see if I can better match the original equipment. Pretty happy with the projection just wish the sizing was closer.
All of these comparisons will be done without any convergence, basic purity and NO Strips.
