20ez v-hold and distorted picture
mochaman
I recapped monitor and installed new flyback. My issue is when the monitor is on for over 10-15 min, it starts scrolling. V-hold pot gets it to stop but the right side is distorted. Adjustments do not help. What would cause this issue? Thanks.
usually that fold over is a cap issue. did you replace every cap on the pcb and did you replace the BP/NP caps. check your work and pots too.
Which cap might be the issue? I'll have to check if I did everyone. Can't remember.
every cap needs to be replaced and ALL have to be checked that you installed the correct cap at the location and that the polarity is correct. we just had a thread on here someone bought some crappy cap kit from another vendor and they had polarized caps in the kit for the two NP (non-polarized) caps.
I'll check the chassis over. I'm sure (99%) that the special caps were NP's.
