20EZ Diode values?
Straker
Ludlow, Massachusetts
I have tested some of the diodes and found them to be bad on the chassis. But the only documentation I found did not list the values of the diodes. Anybody know where I can find a list of which diodes are at which locations on the 20EZ? I'm new to working with diodes so maybe there is something obvious I am missing.
PM me your email and I'll send you a Sanyo 20EZ manual PDF . It has a parts list .
Thanks. I was hoping for something like you see for Caps. Like for example the cap is 160v 330uf. The numbers in the pdf are usefull to do research into finding out info on the diode so I can figure out which current diode part number matches these old numbers.
