Patnukem
Selling a working chassis has new caps including filter, new flyback, new power regulator, new HOT. Also has a new B+ adj pot and has a new 3k ohm horizontal pot.
One issue even with a new power regulator the adjustment over 90v for B+ is not working and will jump to 130v or more, could be another part in the board but works when adjusted just under 90, maybe an easy repair but I was taking too long to wrap up the project it was for, and decided to use my spare chassis.
The power wire was cut and seems to have been wire nut attached to the previous game it was in.
Now including untested inverter board (cap replaced and worked as non inverted did not try inverted) and audio board (audio board is chipped on one corner and another corner that has been repaired, neither seem to break into traces so it would work but will definitely need new caps as one has partially broken off)
(Photo to show picture at 90v for b+)
$175 shipped within the US or $150 pickup in Omaha, Ne Or Best Offer
